Home Cinema speaker set for less than 600
Discussion in 'Home Cinema Speakers' started by PC_112, Apr 19, 2005.
  1. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Hello,
    I am looking for a home cinema speaker set (5.1) for less than 600 pounds. The satellites should be small (preferably less than 20cm tall) but the sub can be big.
    The system will be powered by a quite good amp (Denon 1705 or Denon 1905 or Yamaha RXV-650) along with a Pio 575A DVD player and it will be used for 80% movies and 20% music. (and some x-box games)
  2. rishi
    rishi
  3. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Thanks rishi. Those speakers seem like a good deal but they are bigger than what I would like to.
    I would prefer if the satellite speakers were not higher than 20cm.
  4. Graham_E
    Graham_E
    Nov 8, 2004
    167
    +10
    you could try the infinity TSS-750, just been in What Hifi awards issue with 5 star review etc, RRP is 500 quid, check www.hifibitz.co.uk.
  5. arielshiran
    arielshiran
    as yours as I wanted speakers which will be no taller than 20 cm and be powered probably by a Denon 2105/Yamaha 750/Marantz 5500. My advice to you will be to look at these speakers:
    Energy Take SAT speakers.
    Energy ACT6 system (fits exactly your budget, great reviews in the US).
    Mirage Nanosat system.
    Other great choices which exceed your budget but you may want to consider are: MS Genie, M&K K5s, Castle Compact.
    Good luck. I think trying the Energy sets will be the best idea for you-try them before buying.
    Look at: www.energy-speakers.com for finding the UK distributor.
