home cinema soundproofing
Discussion in 'Home Cinema Building DIY' started by lnewey6, Jun 5, 2005.
  1. lnewey6
    lnewey6
    Nov 10, 2003
    196
    derbyshire
    +3
    im planing on turning my living room into a home cinema the room itself is quite big so im splitting into 2 parts. the room the cinema is going in is 11 foot long 8 foot .wide the sofa will be on the back wall which needs to be soundproofed ,the proplem is do i use resilent channel i have heard mixed reviews so i dont know what to do. also im going to fit a 42 inch plasma and a projector do you think the room will be too small and will bass traps be alright for behind the sofa. thanks
  2. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    will let others more knowledgeable comment on the soundproofing, as for bass traps, dont forget to check the powerbuys.....the standard version can be placed anywhere and the corner units in a corner..lol
