Home Cinema Sound Help
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by milanlad, Oct 3, 2004.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I would like to know if its possible to use a 5.1 processor / amp with the following uses:
    1. In "3 Stereo" mode, i.e. just with the front speakers and centre speaker. In a situation where you don't have the option to set up your rear speakers.
    2. Normal stereo mode, if you just wanted to connect a CD player and listen to music.
    I'm fairly new to home cinema and not sure about current good models, so can someone suggest some processors and amps, or all-in-one receivers. I'm looking for good sound quality as I want to listen to my CD's through the system. I would probably have a separate CD player.
    My budget for processor / amp combination or receiver would be between £500 - £800.
    Hope this makes sense.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    All the receivers I've had, and my current MC-8B processor have an onscreen setup menu and you just tell it exactly what speakers are connected. I would therefore think that most if not all receivers/processors could be set up for just the 3 front speakers and no surrounds. For CD listening you just set the CD input to stereo and the centre speaker will not be used.
    Mark.
  3. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    What is the main difference between a Home Cinema Amplifier and Receiver?
  4. NaimBoy
    NaimBoy
    Dec 11, 2003
    98
    Receivers have a built in tuner, amplifiers don't.
  5. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    TV tuners and/or Radio Tuners???
  6. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    Radio Tuner :)
    Steff
