I am wanting a solid home cinema setup. It's solely for movies and I really don't care at all about music, so if I have to sacrifice anything that is fine!
It is for my LG 4K 3d oled tv so I have to be sure it's compatible with that. The cinema system is for my second room so ideally I would like a budget of £1000 (maybe add some later for a second rear set). I'm not sure how much I ought to spend on these, but if possible I'd like to say, be able to get the rear speakers at a later time and run 2.1 until I have the money for the rear (if the setup is going to be very expensive).
Have any of you tried the Cambridge Audio 5.1 Aero speakers?
How much would I have to spend to go 1 up from that? Are the speakers... 'wow' quality. I'm not sure how much theatre systems go for but at 1k its pretty pricey (it might be on the low end of audio? I've no idea).
Cambridge Audio AERO 5.1 Black | 5.1 Speaker Package | Richer Sounds
Do I need to buy cabling? I believe monoprice cable is what I want, but what size and connectors/tools?
