Home Cinema- Sitting Room
Discussion in 'Home Cinema Building DIY' started by mason, Apr 7, 2005.
  1. mason
    mason
    Dec 17, 2003
    2,068
    Stirling
    +135
    Ok.... my home cinema seemed complete and now I have purchased a nice shiney projector!!! :smashin:
    I have got myself a Panasonic AE700- and it is superb!!!
    The plan was to put the projector on a rack in the back corner of the room... the rack would also hold my kit as well. I moved the kit and fitted the screen etc. buut I was trying to get too much out of the lense shift!! :thumbsdow
    I have now mounted the projector onto the wall an the picture is superb!! :smashin:
    My only problem now is that I have visable wires coming from the PJ to the kit.... would you 1. hide the wiring under some trunking and simply paint it to match the walls? or 2. put the wiring behind the wall (which of course will be messy)?
    Pictures will follow!!
  2. shodan
    shodan
    Dec 11, 2001
    11,369
    shoeburyness
    +6,153
    Cool, look forward to the pics!!!
  3. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,929
    Babel Sensurround
    +207
    Kindly remove digit from your rectum and get some pics on here :D
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,538
    Near London.
    +208
    Yup. :thumbsup:
    Otherwise, if you're planning to stay in that house for 5 years or more than channel the cable into the wall. < 5 years then go for trunking. :)
  5. mason
    mason
    Dec 17, 2003
    2,068
    Stirling
    +135
    I will get the pic's on tonight pre cable hiding!! :smashin:
    I think I will be going for the trunking though- far less messy!!
  6. mason
    mason
    Dec 17, 2003
    2,068
    Stirling
    +135
    Here we go folks.... the first pictures of the PJ set up. I currently have no TV as it got taken away for repair.... the unit looks bare as theres usually a 42" Sony rear-pro/lcd tv on it, however, it wont be long before its back :smashin:
    I am awaiting new component and scart cables (5m) that will be long enough to put the DVD player back on the rack!! When its back on the rack it will be getting replaced by a prog. scan player.
    A bit of work to be done with the cables, so hopefully this will be done over the weekend and fresh pics will be shown of the system complete!! :smashin:
    The picture quality of the PJ is superb- its just a pity I am rotten at taking pictures and I therefore dont do it any justice.
  7. inzaman
    inzaman
    Dec 16, 2002
    7,955
    Derby
    +1,021
    Looks good and looking at the PJ and wires etc i think that trunking will be just fine.
  8. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,616
    Bristol.
    +309
    If you do use trunking with an adhesive back do be aware that it leaves a real mess on the wall if you ever need to pull the trunking away/off.
    Nice set up by the way. Congrats.
    Pete. :)
  9. mason
    mason
    Dec 17, 2003
    2,068
    Stirling
    +135
    cheers mate :smashin:
    Thats the problem... if the trunking does have to come away then it will be a bit of a mess!! but then i suppose if i put a couple of holes in the wall then that will make a bit if a mess also. I went to get the trunking yesterday and forgot!!! :suicide:
    I did however... manage to change the ceiling light in the room and successfully install a spot light.......and............ it works!!! :smashin:
  10. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,929
    Babel Sensurround
    +207
    Well if that's the case you can get your cheeks round here and do mine for me :laugh:
  11. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,616
    Bristol.
    +309
    I thought a man of your means would have a sparky in to do that :D
    After the bargain pro install :eek:
    Pete :thumbsup:
  12. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,929
    Babel Sensurround
    +207
    I Don't do manual labour :p :laugh:
  13. stevegreen
    stevegreen
    May 14, 2001
    8,726
    in my Hymer
    +921
    Mason, where did you get the shelf thing for your PJ from?
  14. lunker
    lunker
    Jun 21, 2005
    239
    +9
    It's looks a lot like the shelf I got from B&Q for my 14" portable with a wooden shelf replacing the metal one that came with it.
    Nice idea!
  15. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,929
    Babel Sensurround
    +207
    From memory i think it is a piece of pineboard fixed to a tv wall bracket.
  16. stevegreen
    stevegreen
    May 14, 2001
    8,726
    in my Hymer
    +921
