Home Cinema Setup
Discussion in 'Home Cinema Building DIY' started by rooker7, Oct 14, 2004.
  1. rooker7
    rooker7
    Right lads, i need some serious guidance here.
    I'm looking to setup a Home Cinema/Intergrated Tech Setup that i could primarily control from my laptop.
    I need the following :
    LCD TV (30"+) will be used for PC display and TV
    Sky+ 160
    Music Server
    DVD/HDD Recorder
    Speakers (I have no knowledge at all on speakers)
    DAB Tuner/Digital Radio (Looked at the Goodmands GCD200 i think thats the model no)
    Is that all? I have a £5000 budget so if you could reccomend any products i'd appreciate it.
  2. asimm
    asimm
    Aug 3, 2000
    1,516
    48
    +75
    rooker - if you want good sound from Sky+ (sky movies outputs dolby digital via Sky+) then get a HC amp (unless the musuc server will cover this). If you have a good amp and sky + through it then there might not be a need for a digital radio - Sky + has them all.
