S
systemsetup
After hours and hours of research I hope I have the makings of a decent system that (just!) within my budget now.
Would very much appreciate any comments/feedback and especially some help in terms of cabling. (Decorating the room before all equipment turns up and I need to get bits of this right rather than cause a re-decorating disaster later!!)
Panasonic TH42PW6B 42" Plasma Monitor
Denon DVD2200 DVD Player
Denon AVR2803 Receiver
KEF Eggs
In terms of cabling I plan to use a RJB/VGA converter from JSElectronics for Sky + and component video on the DVD (does that sound like the right way to go?)
But what I really need to get done in a matter of days is put suitable speaker cables in place as a new floating floor is going down next week.
Any recommendatios on cables for such a setup - think I read on other posts QED at £5-£10 a metre would be adequate.
But what about the connectors on the cable? Can anyone tell me what terminations I'll need on each end of the cable to connect the Egg's/AVR2803?
Many Thanks
KEF Eggs
Many Thanks
