home cinema receiver
Discussion in 'Projectors, Screens & Video Processors' started by lonestar, Sep 22, 2003.
  1. lonestar
    lonestar
    Jul 26, 2001
    179
    maghera, n.ireland
    +3
    hello all,
    is a home cinema receiver the only box I need to connect my satellite reciver, dvd, video and ps2 to a projector, which will allow me to watch any of the above inputs on a large screen?
    a simple question, and one which I hope can produce a simple answer. For the record I'm not too interested in going down the hcpc route.
    Thanks.
  2. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Sort of...
    You can plug in any composite video (yellow phono plugs) s-video (mini DIN connector) into a receiver and output though the monitor out connection. When you switch sources the video and audio will be switched.
    Here's where the "sort of" comes in...
    The trouble is not every piece of AV gear has s-video outs and no AV amp or receiver has SCART connections so you either have to
    live with poor composite video (lowest quality, which will be VERY apparent on a PJ) or get a convertor from RGB scart to s-video. These cost around £70 - £100.
    Depending on the projector you may also want to improve the image with a line doubler/ deinterlacer. This converts the interlaced image to progressive scan and increases the number of line in the image which will also be very noticeable on a PJ. Some PJ's (the CRT variety) include a deinterlacer/doubler in the chassis.
    Also bear in mind that running video thru the receiver degrades the signal somewhat.
    hth,
    Owen
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,789
    Somewhere in South Yorkshire
    +4,975
    Theoretically true, although in practice rarely to any discernible extent.
    This is exactly what I do. Svideo and Composite video (plus, audio of course) from all appliances into AV amp. SVideo and composite from Amp to projector.
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +174
    FYI. Maplins do a RGB to S-Video transcoder for around 40 quid and I was more then happy with the results out of my Cable box to Panny AE100.
    It almost looked as good as component video :)
    Well worth a look.
  5. lonestar
    lonestar
    Jul 26, 2001
    179
    maghera, n.ireland
    +3
    thanks for all the replies, I'm a little bit more clued in as to what I'll need to achieve my home cinema setup, which will probably be based around the infocus x1 projector.
