Hi all,
I have recently purchased a home cinema system (HC) and I'm having a bit of a problem with the connections. I'm normally quite good at this type of thing but I seem to have run into a bit of dead end ideas wise....
System
HC = LG HT806PH (1 x HDMI out + 1 x Optical In)
HDTV = LG 42LK530T (3 x HDMI in + 1 x Optical Out)
Xbox 360 - older version without HDMI
Setup
HC - HDTV = HDMI
HDTV - Xbox = Component
Problem
When viewing HDTV I run an optical cable from the TV to the HC, however when I want to switch the xbox on I have to remove the optical from the TV and plug it into the xbox as the component cable does not carry 5.1. Is there a way I can avoid the manual switching of cables?
I've looked into optical switches yet I do not believe these would work as I understand one of the devices needs to be switched off and when running the xbox all would be on.
I've also looked to see if there is a way to get my xbox to carry 5.1 direclty to the TV other than via optical, this would solve the problem as my TV allows 5.1 pass through.
Willing to purchase add ons, extentions, converters but not major kit.
Any help or suggestions would be appreciated
Thanks in advance
System
Setup
HC - HDTV = HDMI
Problem
Thanks in advance
