Home Cinema Kit
Discussion in 'Home Cinema Speakers' started by iaria, May 13, 2004.
  1. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Well I am not too sure this is the right place to put this question, but here it goes
    I have been asked by a friend to find a Home Cinema kit for his new house. The room it will be used is about 25 by 25 foot, quite large, the price he intend to spend is £ 5.000 and not a penny more if possible
    The kit must consist of a projector and screen plus amplifire (6.1 at least) and speakers and subwoofer to fill the room with sound.
    Hope some of you can come up with some suggestions
    I thank you in advance
    Gerry
  2. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    I think I will talk by myself if nobody wants to reply :lease:
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You are asking rather a lot as it would be a fairly lengthy job for anyone to research the possibilities of DVD player, amplifier, speakers, projector and screen when all we are told is that the budget is £5,000
    May I suggest that you research the various options yourself then post your ideas and ask for opinions on what you have shortlisted. The hardware reviews from Home Cinema Choice are a useful resource.
  4. theroohster
    theroohster
    Just a suggestion...
    Kef Q7 AV package £2,200
    Arcam AVR300 Amp £1,300
    Panasonic PT-AE100E Projector£1,500
    Of course your friend may want to spend less on speakers and upgrade to a DLP projector, but this setup would be my ideal for £5,000
    If he buys the lot at the same place, he should be able to get all the cables and a reasonable screen thrown in.
    You didnt mention a DVD player in your query, so Im assuming he already has one?
  5. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Thank you for the reply Ian and Theroohster
    tomorrow (saturday) I will go to my local 7oaks sound and vision and will pick their brains, and will come back to you to let you know the results
    Once again thank you
    Gerry
