Home Cinema kit needs replacing
Discussion in 'Home Cinema Buying & Building' started by Bleem, Feb 6, 2009.
  1. Bleem
    Bleem
    Jan 4, 2006
    7,681
    Glasgow
    +2,465
    Howdy,
    My LG DA-5620 (2002) is about to kick the bucket so I'm looking to replace it with something similar. Things seem to have moved on quite a bit for home cinema since I shopped around for the LG though.
    Can anyone recommend a good piece of kit that will 'do the job'? I'm not looking for anything fancy and am more concerned about the number of inputs rather than getting top notch output.
    Kit that needs to connect..
    Sky +HD (HDMI)
    Xbox 360 (Optical)
    PS3 (Optical)
    Even if you can't recommend a particular make/model - are there any I should steer well clear of?
    :smashin:
  2. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    Budget is gonna be a big factor in peoples reccommendations. Also are you wanting seperates or a all in one like your current LG? If its an all in one your better posting here:
    All-in-one Systems - AVForums.com
  3. Bleem
    Bleem
    Jan 4, 2006
    7,681
    Glasgow
    +2,465
    Yeah it's really an all in one I'm after - could you move the thread please?
    :smashin:
  4. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    Moved as requested.
