Home Cinema Kit Advice
Discussion in 'Home Cinema Buying & Building' started by Moncs, Jun 16, 2005.
  1. Moncs
    Moncs
    Jan 14, 2002
    460
    Edinburgh, Scotland
    Waiting on delivery of a Panasonic 42 " PV500 plasma and I am looking for a home cinema kit that would suit this TV.
    Looking for something with component output, can play MP3's and is multi region. Would like a built in radio tuner if possible but not necissally.
    Not to bothered about recordable DVD's or one with a HDD we have Sky+
    Anyone recommend a suitable system? :thumbsup:
  2. Kefre
    Kefre
    I also have ordered Panasonic 42 " PV500 plasma and looking for an all-in-one home cinema system, but haven't found one yet. I think the system should have component output (i haven't seen any with HDMI conection!) and progressive PAL scan. I was told that only certain makes or models can be converted to multi region...
  3. Moncs
    Moncs
    Jan 14, 2002
    460
    Edinburgh, Scotland
    I was thinking of getting the Denon DHT 500SD system which has component output and progressive scan.
  4. lukey
    lukey
  5. Grangey
    Grangey
    Sep 8, 2005
    But that's not multi-region, unless you have a hack? I, too, was going to buy one of these until I looked for a hack and couldn't find one...........
  6. snapper3166
    snapper3166
    Aug 22, 2005
    1,304
    Loughborough
    +80
  7. andrew markwort
    andrew markwort
    Jun 20, 2004
    1,156
    63
    +159
    I can recommend the Panasonic SCHT 530 - scored the equal of the Denon in a head to head comparison, except that it has a lower volume level (should be no worry if you have a smallish room) and lacks the input and output connections of the Denon. But it is 200 or more quid cheaper if you know where to shop, has component video, etc, and plays DVD-Audio (which the Denon doesn't). I got one to replace a Sony that was fading fast and would bide me over for a couple of years until the dust has settled on the transfer to HDTV et al. I can strongly recommend it. The picture is excellent, the sound is perfectly adequate (and the bass level can be easily controlled - something I like as I can lower the bass for late night listening when the kids are asleep).
  8. tony6403
    tony6403
    You could consider a Panasonic DMR 10 DVD recorder ( £150 from Currys ) top of the reviews , plus a Yamaha AV57 surround system - without DVD ( £160 from Empire Direct ) which has HDMI connectivity. The latter got full marks in its review.
