Home cinema house renovation
Discussion in 'Home Cinema Speakers' started by stubo300, Nov 6, 2016.
  1. stubo300
    stubo300
    Sep 16, 2015
    dorset
    Hi all I and looking to install a wired multi room speaker system in my house, I am looking for a bit of advise and what I need and links
    I have installed wires to the following rooms
    4 speaker positions in my lounge (I would like to connect my tv to these speakers if possible)
    2 speakers positions in my bedroom
    2 speaker positions in my bathroom
    2 speakers positions outside
    I am looking to be able to isolate rooms so we don't have to have all the music playing over the house.
    The only speakers I don't need are the outside ones but the rest are needed and need to be ceiling speakers
    Price is a issue so if you can send me links to reasonable price set ups
    Also as a comparison what would i need for a 4 x ceiling speakers and a control box so I can connect my tv to it any links would be great
    Thank you
  2. citywalker
    citywalker
    Mar 7, 2012
    801
    46
    +140
    Are you sure about ceiling speakers? In bathroom they are ok for background music, but for TV it is very strange, if sounds come somewhere over your head, not from correct/front direction.
  3. PSM1
    PSM1
    Dec 20, 2008
    26,271
    +5,426
    I would not recommend ceiling speakers in the lounge for TV usage to be honest as it is not going to sound good and you will just end up using the TV speakers (it is what I do in my kitchen!!!).
    A central system sounds great but can get complicated to control etc,
    Have you considered using something like a Sonos system connected to each room and use that?
    Would you want speakers in different rooms playing at the same time (whether it is the same or different sources)?
    Also how big is your bathroom? Do you need 2 speakers or would one stereo ceiling speaker be sufficient?
    Currently you have 10 speakers which means 10 channels of amplification potentially so you can start to see how the costs can start to mount up.
