Home Cinema HiFi with wireless rears...
Discussion in 'Hi-Fi Stereo Systems & Separates' started by MattDX, Dec 7, 2003.
  1. MattDX
    MattDX
    Does anyone know of a good home cinema hifi with wireless rear speakers?
  2. lovegroova
    lovegroova
    Jul 15, 2002
    2,540
    103
    Herts
    +300
    The trouble with wireless rears is that they need power, which is usually done by the connection of...a wire! It may be shorter than running cable all around the room but usually suffers from ppor quality. Better to get some flat or 'nearly invisible cable and hide it as best you can.
    FWIW I believe Philips do wireless rears with some of their TVs
