Home cinema help what to do when upgrading to DVD recorder
Discussion in 'Home Cinema Buying & Building' started by pionstuff, Aug 5, 2005.
  1. pionstuff
    pionstuff
    I have a Pioneer NSDV99 home cinema system.
    http://www.dooyoo.co.uk/home-cinema-system/pioneer-ns-dv-99/
    But I would like to upgrade my dvd player to a dvd recorder.
    Can i just purchase a new dvd recorder and run it through the system, or do i still need to keep my original DVD player to make full use of the all in one system?
    Any advice appreicated.
    Dan
  2. YorkieAnd
    YorkieAnd
    May 19, 2005
    22
    I too am looking to upgrade from a DAV-SB100 to a recordable DVD with home theatre system. Can anyone recommend a good system as they don't seem to be the easiest things to find. Bearing in mind I am intending to by a HD DLP in the next couple of weeks I would be interested in a player that will upscale to get the best picture possible. Are there any recordable models that would do this and also provide a home cinema sound system? Thanks for any help.
