Home Cinema - help needed!!!
Discussion in 'AV Receivers & Amplifiers' started by electrify_dizz, Apr 26, 2003.
  1. electrify_dizz
    electrify_dizz
    Hi all,
    I posted a similair message over in the speakers section - but i doubt everyone looks there, and I would appreciate the advice!!!
    A few months ago I bought a Toshiba SD 220-E multi region DVD player. At the moment I have it set up through my Cambride Audio A5 stereo system. As you can guess, this is a temporary measure!!!
    Basically, I am looking to spend around £500 with which I want a decent amp/receiver for surround sound, as well as 5 speakers (I will be looking to get a sub at some point, but I am going to be moving house, and dont want to get one until I know i have the space to justify it!!!)
    I was hoping for some advice!! I am looking at getting the Eltax Liberty 5 speaker package, and a yamaha amp, however I am looking around at the moment, and was wondering what fellow users would advise!!!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I suggest you get to alocal dealer explain your budget and demo then ask again
    PS Eltax are not great
    Marrantz 4300 or Denon 1603 amps and speakers by Mission M72 package maybe you reallly need to demo them!
  3. miniman
    miniman
    Apr 14, 2003
    568
    Birmingham
    +7
    I agree you can't go far wrong with the marantz or the denon but also you must demo them and a few more and trust your own ears
  4. tommymuldy
    tommymuldy
    Mar 6, 2003
    11
    London
    I have the yamaha nsp220 speaker package which I got for about £100 a month ago, and the yamaha htr-5540rds amp and that cost me £200. I seriously can not fault the performance of the two together. Just to let you know, I got the deal from robertsons on line in Leeds. Pretty good service there as well (only took about 3 days to arrive to me in London).
    Good luck
  5. hamtaro
    hamtaro
    if you can get them, anything by mission that richer sounds have , may help.as far as amps go they do have some bargains. its just been there at the right time.i bought a denon 1802, and although it was a cheapo im happy with it.
  6. knoxy
    knoxy
    Nov 6, 2002
    201
    Manchester
    +31
    what about...
    yamaha rxv430rds - £150 (apparently at hyperfi.co.uk although not on website)
    mission m71i fronts - £90
    mission m7ds rears - £125
    mission m7ci centre - £75
    Thats £440 leaving you enough for P&P annnd a pair of mission stancette speaker stands for £50 if you need 'em!
    Well, it's what I intend to buy within the next few weeks!! Well, maybe the m72i's for the fronts for an extra £20 instead of the m71i's...
    hope that's any good to you!
  7. electrify_dizz
    electrify_dizz
    Hey guys,
    Thanks for all the advice.
    I've been looking around, and have found a Rotel RSP 966. I was wondering if any of you are familiar with it, and if so what the quality of it is like.
    With regards to the speakers, Im personally a huge fan of floor standing at the front. This is the main reason I was looking at the Eltax Liberty's. However, if they will be out performed by normal speakers I will look into those!!
    But any info on the Rotel would be appreciated!
  8. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    The Rotel RSP966 you meantion is only a processor (IIRC) so you would also need power amps to go with it.
    In general, budget floorstanding speakers are always outperformed by similar priced stand mount speakers.
  9. nathan_silly
    nathan_silly
    A mate has the Rotel 966. It's pretty awful, lots of noise decoding Pro-Logic, hiss in Dolby Digital, hums in DTS. Because of the background noise, it masks fine detail in the sound.
    It's also a very big unit. He upgraded to a Denon AVD-2000, and it sounds ALOT better. No noise, no hum. I will never touch any Rotel pre-amp.
  10. Field
    Field
    I bought a fairly budget home cinema system around 2-3 years ago and use the Mission m73 floorstanders as the front speakers. Have to say that for the money (probably around £150 these days?) they are truly superb for home cinema purposes, the relatively large cabinet allowing excellent bass for a reasonably priced speaker, especially when placed near a rear wall. Not quite as accomplished on the hi-fi front but still very acceptable for the money.
    So if you're set on floorstanders for the fronts, as I was, then I would give them a try.
  11. scooby do
    scooby do
    Dec 11, 2002
    1,984
    48
    +83
    Hi there don't know what happend to my post but send me a PM and I may have something for you!
  12. electrify_dizz
    electrify_dizz
    I will throw the Rotel out the window then!!!
    Thanks again guys!!! I intend to go into either Reading or Basingstoke on Friday, so I will build up a short list then, and come back asking again!!!
  13. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    yamaha 430 - £150 + mission 77se £399 if you can stretch the extra 50 for the floor standing fronts or
    yamaha 430 + mission m72 £199 with cash left for connects,cables or sub all from Hyperfi.
  14. scooby do
    scooby do
    Dec 11, 2002
    1,984
    48
    +83
    Robin I have sent you another PM in response to yours
    Regards Graham
  15. electrify_dizz
    electrify_dizz
    I'm setting up a demo with richer sounds to have a look in about a fortnight. But before I do, the denon and marantz mentioned earlier - are they any good for music?
    Im asking as I recon I could just about scrape together £600, so I may be able to spend a bit more if I get better music output as well!!
  16. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Both are ok, but neither is as good as your Cambridge Audio A5 (unfortunately)
  17. electrify_dizz
    electrify_dizz
    Thats a pain in the butt. That will definately be one feature I will be looking for, I dont really want to have two systems in my room (as im a student, this is all going in my bed room at uni!!)
  18. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    'eltax are not great'
    I disagree, they may make some cheap speakers but they also make some excellent ones. I have a set of Linear Response floor standers and think they are great. Trust your own ears not some one else.:lesson:
    Mylo
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If you go fo an amp with preouts you can use you A5 for the front pair and connect the CD plyer and other 2 channel sources dierct.
    For stereo perfomance of the A5 you need to look at higher end kit
    A yamaha DSP 800 i think might be worth a look. £250 online
  20. electrify_dizz
    electrify_dizz
    Hi all,
    Right, I went into Richer Sounds today. They pointed me towards the Sony STRDB780 and the Marantz SR5300 amps, and then the Eltax Liberty series speakers. They didnt have any missions in at all which is a bit disappointing.
    I have set up a test date for next week for it all. Both amps are 299, and the speakers are £250.
    Does anyone know much about these for a set up?
  21. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    You Can not go far wrong with the Marantz as far as AV amps go in stereo I love mine not sure about the speakers, try and take your amp with you as a comparison for stereo replay (use source direct on the Marantz) after all it is you that has to live with the system. If you feel the Cambridge is better I would save yourself some money and go for a 4300 and follow hornydragon's suggestion of running the front speakers from this. Use the extra money for better speakers.
