gazyang
Established Member
Hi guys, i think its about time i started a thread for my first attempt at a loft cinema and gaming room.
All comments welcome.
Room dementions are: 3.5M wide by 5.5M long.
This is all being done on a tight budget so i should state that every thing in this build apart from the AV kit is all salvaged or reused even the plaster board was from off cuts that my brother gave me from work used on new builds in maidstone.
All the shelving and surrports were from off cuts and spare wood in my garage or from my previous D.J. cabinet which had my turn tables, mixer,amp,cd recorder and all my records stored underneath, it also run the full width of the room. So far the only things i have purchased new are screws, wall plugs, polifila, and paint.
It should also be noted that im playing it by ear, so to speak ^^ i do things on the fly as i can never completly get it straight in my mind, i figure out or solve a problem then it gets done. so if things look half done in places its because i either changed my mind or have not sussed out which colour paint or wallpaper to use, well you get the jist of it so here goes.
All pictures are taken using my samsung note.
first off i mounted my tv to the wall using a bracket purchased from asda for £15 it was the slimest i could find, i need the tv as close to the wall as possible.
[/IMG]
