Woodhill
Established Member
- Joined
- Sep 6, 2009
- Messages
- 74
- Reaction score
- 12
- Points
- 44
I need help. I am about to convert a room to a home cinema. It will also be used as a living room (most of the time).
The room is 6.5 metres by 5 metres. I have a budget of about £5,000 for a projector, AV receiver, and speakers. Of this , I think about £2,000 will go on a projector.
I have no special preferences but the projector should give a good quality HD picture on a 2.5 meter wide screen with some ambient light.
I will be using the system for Sky HD, PS3, X-box, and a Wii. About 5-10% of the use is gaming. The rest of the time, it will be used for movies and TV.
There is so much conflicting advice out there. Can you help me narrow my choice?
