Home cinema for less than a grand!
Discussion in 'AV Receivers & Amplifiers' started by Richb1888, Aug 7, 2013.
  1. Richb1888
    Richb1888
    Jun 23, 2012
    50
    +13
    Hi all,
    I'm sure plenty others have asked this before but it's a bit of a minefield out there really! Basically looking for a decent home cinema system for £500 -£750 ish. Happy to spend more if it justifies it but hoping I can get a decent setup for the cash.
    So here is my wish list
    5.1 surround sound or even 7.1 (do the extra 2 speakers justify themselves?)
    Obviously top quality sound for both music and movies
    Blu ray player
    smallish/discreet satellite speakers.
    Reasonable amount of inputs
    The ability to stream music from computer
    Control via a smartphone app.
    If possible the ability to output to speakers in another room(s)
    Is pairing iPhones etc via Bluetooth a possibility? (Handy for a party when someone else wants to play music from their device)
    Any other things I should be looking for?
    I did initially consider the sonos playbar but by the time you add 2xplay 3's for rear speakers and a sub it all gets a bit pricey, and lets be honest..... It's ugly!
    Got a nice panny txl55wt50 to play my movies on and think the playbar would look terrible underneath!
    Thanks in advance guys and look forward to hearing your opinions/suggestions on any of the above!
    Rich
  2. Richb1888
    Richb1888
    Jun 23, 2012
    50
    +13
    Obviously if there's a decent system out there for less than £500 I'm ok with that too!! :)
