I started the work this week, but it's slower progress than I anticipated.
Tell me about it. I started in June and told the kids it would be ready around the end of the summer holidays. It's still not ready.
I do have question: what height did you put your LCR and back speakers? I now it's supposed to be ear level, but that kinda depends on the sofa / chair, so I assume there must be a rule of thumb.
LCR between ear level and centre of the screen. If you're going for typical cinema recliners, ear level could be around 40". If you're going for cinema chairs, it's a bit higher.
So plan your screen size and height now, so you can work it all out.
Rear speakers are different. If you're having atmos, and 1 row, then rear can be close to ear height, but needs to be high enough to clear the back of your seats. I'd say as low as possible, that clears the back of the seats. That may mean building with ability to raise or lower them, once the seats are in and you can test. That's what I had to do.
I'm aiming to put them at 1.3m height (measure at the middle of the speaker), or is that too high?
It depends how high the screen is. If the screen is high, that may be ok, but if not, that might be a bit high. And you measure to the acoustic centre of the speaker, which is usually closer to the tweeter than the woofer. I couldn't fit mine low enough (room constraints), so I've installed my speakers upside down.
