Question Home Cinema Design Priciples
Discussion in 'Home Cinema Building DIY' started by Pulsar, Nov 18, 2018.
    1. Pulsar
      Pulsar
      Jan 19, 2003
      3,172
      West Midlands - Stourbridge
      +343
      I am in the very early planning stages of a dedicated garden cinema room. At this stage everything is up for debate including room dimensions / ratios, layout, screen size etc. Can anyone here recommend any resources that I can use to help self-teach some of the basics of good cinema room design?
      Rob
    2. Peter Parker
      Peter Parker
      Apr 6, 2001
      13,551
      UK.
      +3,056
      I like the CIH + IMAX option.
      So you fit the biggest 16:9 screen you can fit for your preferred seating distance, and you mask the top and bottom so you have a 2.40:1 screen.
      You watch 16:9 within the 2.40 screen height, and then zoom (or use an Anamorphic lens) to make the image wider for scope ratio movies. You will need a projector with lens shift as well as a zoom ratio of greater than 1.33. DLPs are usually restricted in that regard so other brands like Sony JVC and Epson will be more suitable.
      If you get a movie that has aspect ratio changing for IMAX elements (The Dark Knight, Interstellar, Dunkirk etc), you keep the image zoomed to the width and just remove the top and bottom masking so the IMAX portions are visible when they occur. That way all movies are presented correctly with respect to their aspect ratios and the largest movies are seen largest, and the smallest as smallest.
      For this to work you have to ensure your seating distance is close enough so that 16:9 is as large as you feel comfortable with, so that it doesn't feel too small. That's usually based on how tall an image is as taller images become more uncomfortable to watch over long periods than wider ones.
      THX recommends a seating distance of 2.4 x the screen height for the primary seating position, with 3.68 x the SH for the back row. SMPTE/CEDIA recommend sitting no closer than 2xSH (and no further back than 4xSH, with a starting point of 3xSH), and no seats closer than would provide a vertical viewing angle of 35 degrees or more, with 15 degrees max being recommended. IMAX viewing is a little different with these rules but the usual rules for scope can apply there.
      What we usually recommend is projecting an image onto a wall and experiment with different image sizes and ratios, as well as different seating distances, but most people end up within the guidelines.
      Dolby, THX, SMPTE and CEDIA all have guidelines to which commercial theatres are built to and most of it can be found online if you want to build something that will be similar to commercial theatres/screening rooms.
      Square rooms are usually considered bad.
      Having an acoustically transparent screen with speakers behind is one approach, and having the room covered in black velvet so that you can only see the projected image is considered good for image quality. Reflections from the screen onto reflective surfaces and back onto the screen can reduce intra-image contrast and sometimes be a visual distraction. Some people like a room that is visually pleasing when the lights are up so you have to decide what you prefer.
      I suggest you use Dolby's commercial guidelines for speaker placement, especially with respect for Atmos:
      https://www.dolby.com/us/en/technologies/dolby-atmos/dolby-atmos-specifications.pdf
      Don't have seats against the back wall, and try and keep speakers at least 4ft away from ears. Surround speakers should be at approx ear height to give a larger separation to the ceiling Atmos speakers. That's not always possible in small rooms with multiple seats and rows.
      Acoustic treatments usually help too.
      That should get you started.
      • Agree Agree x 3
      • Thanks Thanks x 2
      • List
    3. DougAP
      DougAP
      Oct 14, 2012
      1,471
      116
      +699
      • Like Like x 1
      • Thanks Thanks x 1
      • List
    4. DougAP
      DougAP
      Oct 14, 2012
      1,471
      116
      +699
      Cross-posted with @Peter Parker , but glad to see we agree on the first principles to consider!
