Home cinema build, Need help with LED lights.
Discussion in 'Home Cinema Buying & Building' started by atosoup, Nov 2, 2017.
  1. atosoup
    atosoup
    Nov 2, 2017
    uk
    HI all , new here and have just spent the last hour reading the forums,, awesome stuff,,
    I am currently mid build on my home cinema room, ( Will post pics in other thread )
    The problem I need help with is my led lights, I have LED strip 5050 lights running round the top of the walls on all four sides connected to a power source and a wall mounted glass touch switch mounted in the wall next to the rooms light switch, I have also purchased a wireless switch that allows me to control the lights from an app on my smartphone, Both work great wired up individually but I would love to have them both connected at the same time, But I can not figure out how to wire them both up at the same time.,
    Any help or advice much appreciated,
    This is the switch I have
    5050 3528 LED Strip Control Wall Touch White Glass Panel RGB Dimmer DC 12V 24V | eBay
    This is the wireless remote
    Mini Wifi Controller Android IOS Cell Phone DC Adapter For RGBW LED Strip Light | eBay
