Quantcast
Home Cinema and Video source compatibility
kategdy
Hello,
I have 4K Ultra Blu-ray Player (UBP-X800M2 4K UHD Blu-ray Player With HDR) and I wanted to buy home cinema for it. I bumped into Bose Lifestyle 550.
On official website it says "It supports 4K resolution at 4096/60p with 12 bit. (Same as Lifestyle 600/650 systems.) "
But on other sources I see Lifestyle 550 have 4k but without HDR and 30hz not 60hz.
So what is the truth? As I want to use mine Player fully.
gibbsy
Bose = Buy Other Stereo Equipment.
Plenty of much better AV out there for your needs but it would help others if you mentioned exactly what you want out of any connected equipment. Starting point would be an AV Receiver, then a speaker set up which would need five speakers and a sub woofer. However this may not be right for your room and so again to help others help you perhaps you could post a plan of your room and where the TV is going to be positioned. Last but by no means least a working budget.
Roohster
Plenty of much better AV out there for your needs...
Totally agree, for that kind of money there are loads of better options.
If you don't feel confident matching components,quite a few retailers offer receiver & speaker packages.
