binap
HOME CINEMA BINAPTIKUM 4K
7.2.6 Auro-3D -optimized setup with Front Heights and Rear Heights at 30° Elevation,
additionally 2 x Top Middle for Dolby Atmos
additionally Top Surround (Voice of God) for Auro-3D
additionally Center Height for Auro-3D
A Denon AVC-X8500H is supporting 15 speaker terminals, which is switching the setup configuration depending on the incoming 3D surround signal Auro 3D or Dolby Atmos. Maximum 13 channels could be used at the same time. The other pair of speaker has no signal.
Setup 1:
Auro 3D (extended Auro-3D of the X8500H)
7.2.6 with Front Heights, Rear Heights, Top Surround (VoG) and Center Height
Setup 2:
Dolby Atmos:
7.2.6 with Front Heights, Rear Heights and Top Middles
Biggest benefit is the Auro-Matic Upmixer functionality with 13 Channels!
Details:
Speakers in 7.2.6 Setup:
Fronts: 2 x Jamo Concert 11 (Jamo D870)
Center: Jamo Center Concert (D8CEN)
Surround: 2 x Jamo D500 LCR
Surround Back: 2 x Jamo D500 LCR
Front Height: 2 x Jamo D8SUR (modified to monopol, backside deactivated)
Top Middle: 2 x Jamo D500 LCR - Dolby Atmos only
Rear Height: 2 x Jamo D8SUR (modified to monopol, backside deactivated)
Center Height: 1 x Jamo D500 LCR - Auro-3D only
Top Surround / Voice of God: 1 x Jamo D500 LCR - Auro-3D only
Subwoofer: 2 x SVS SB 3000 with 13" driver, 17 - 260 Hz +/- 3 dB, 800 Watt (2500 Watt Peak)
Amplifier:
Main/Rear/Rear Surround: IOTAVX AVXP1 7-channel-amplifier
Front Heights, Rear Heights, Top Middles, Top Surround, Center Height: Denon AVC-X8500H
Projection und Screen:
Beamer: Sony VPL VW270 (4K, 3D)
3D-glasses: 4 x Hi-SHOCK® 3D-BT Pro "Black Diamond" black, 4 x Hi-SHOCK® 3D-BT Pro „Oxyd Diamond“ black
Screen: VnX Atlantis Dream Mutiformat-Tension, 265 x 150 cm, Gain 1,0
Single components:
Sat-Receiver 1: HDTV-Receiver Kathrein UFS-912 with TitanNit 1.98
Sat-Receiver 2: HDTV-Receiver GigaBlue HD 800 Quad mit OpenATV im Flash
HD-DVD-Player: Toshiba HD-XE1
Blu-ray-Player 3D: Oppo UDP-203 4K Ultra HD Blu-ray Disc Player
Multimedia 1: madVR HTPC
Multimedia 2: Xbox 1 mit XBMC (720p)
Multimedia 3: Xbox 360 + Kinect (1080p)
Multimedia 4: Sony Playstation 4 Pro + PSVR
Multimedia 5: Apple TV 4K
Multimedia 6: Xbox Series X
Home Cinema Controlling
Universal Remote: Logitech Harmony 950 with Harmony Hub
Light Control system: Philips Hue Bridge
Cinema room
Size: 5,83m x 3,86m x 2.40m
Seating: 4 (2. row) + 2 (1. row)
Cup holder: 3 x Speedmaster Cupholder, modified
Home Cinema door: Herholz SST 3-2, Class 3, erf. RW: >37dB
Hifi-Rack: Spectral Sideboard
Room correction system (LFE): DSPeaker Anti-Mode 8033 Cinema
Acoustics:
DIY absorbers: 6 modules ceiling absorbers (ceiling integrated), 4 modules wall absorbers, 8 modules corner absorbers, Open podest with low frequency absorber,
Absorbers material: 11cm Isover SSP2 (40mm) + SSP1 (30mm) + SSP1 (30mm).
Skyline-2D-diffusors: 8 modules Sonitus "Bigfusor" at the ceiling (240cm x 120cm), 1 DIY module "BinaFusor" at the backside wall (60cm x 60cm)
Setup 1:
Setup 2:
Dolby Atmos:
Details:
Amplifier:
Single components:
- 2 x 8m Philips Hue LightStrip+ RGBW Strip (ceiling light )
- 2 x 3m Philips Hue LightStrip+ RGBW Strip (absorbers)
- 2m Philips Hue LightStrip+ RGBW Strip (Home Cinema Seating)
- 6 x GU10 Philips Hue White Ambiance
Cinema room
Acoustics:
