Home Cinema? £200-300 and want to attach laptop?
Discussion in 'Home Cinema Buying & Building' started by Komodo, Apr 26, 2007.
  1. Komodo
    Komodo
    Apr 26, 2007
    24
    Hi all!
    Want to pick your brains please. Looking to buy a home cinema system with dvd player but only got £200 stretching to £300 to spend. Im hoping for multi-region and pro logic 2. Also want to attach it to my laptop so can play music off that through the speakers.
    Am i being realistic or will i need more cash?
    Any suggestions would be greatly appreciated.
    Helena xxx
  2. mikee_j
    mikee_j
    Apr 27, 2007
    39
    i'm in the same boat helena, £300 to spend and want the same features...
    interested in responses...
  3. neh0
    neh0
    Aug 25, 2005
    125
    +11
    Depends on what you want to do. If the laptop has a 3.5mm jack you'll need a 3.5mm to RCA phono lead and a system with an aux (RCA) input. If your laptop outputs digital you'll need an spdif lead.
    Once you know your input source you can look for a cinema system.
    At the 200-300 price point you might not get all the options and inputs you want in an all in one.
    Might be worth considering a speaker system like the Sony SS1000 and connecting this to a 'cheap' DVD player. This would give you more verstaility and choice of inputs.
    Hope this helps,
    Neil
  4. Komodo
    Komodo
    Apr 26, 2007
    24
    Hiya Neil thanks for the advice. Sorry dealing with a total newbie though. How do I find out if my laptop outputs digital am I looking for a certain connection. Doubt it has as fairly cheap one but would like to be sure first. Like the look of that ss1000 have heard that Sony's are usually quite good.
    Thanks for your help much appreciated.
    Helena xxx
  5. neh0
    neh0
    Aug 25, 2005
    125
    +11
    Helena, I'd suggest checking out the documentation and manufacturers website for the laptop.
    I'm biased about Sony atm :)
  6. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    i would say,to look in the manuals of the laptop for something called "DVI out".
    if your laptop is vga out only,it will connect to the average lcd tv,but the sound would then have to be connected to the surround,to get the effect.
  7. Komodo
    Komodo
    Apr 26, 2007
    24
    Hi all doesnt look like my laptop does digital out so not going to bother withi it.
    Like the look of the ss1000 but have seen an ss1100 on websites as well. Does any one know anything about this is it a higher spec or lower?
    So definately thinking get amp and speaker set and dvd seprate is the best way to go?
  8. Komodo
    Komodo
    Apr 26, 2007
    24
    Hi all.
    Right decided to get a set top box with 2 scarts and getting a samsung dvdhd870 dvd player. My tv is only an old CRT 32" with 2 scarts and audio L/R wahtever that is called. Thinking of getting the sony ht-ss1100 will i be able to attach all this together as not sure that the amp has a scart socket?
    Advice needed please before make an expensive cock up. :confused:
    Helenaxxx
