Home built sub (pics)
Discussion in 'Subwoofers' started by IPPacket, Apr 9, 2003.
  1. IPPacket
    IPPacket
    Hi Guys,
    Having recently been addicted to setting up a home theatre system I decided to build myself a sub. Here is the end result. Goes very nicely mind you. All for less than $500 Aussie dollars :D
    http://forums.overclockers.com.au/showthread.php?s=&threadid=138656
    All the inspiration was taken from this article
    http://forums.overclockers.com.au/showthread.php?s=&threadid=89822
    If anyone is thinking about building a sub themselves, I recommend it as it is very satisfying and fairly easy. I think the last time I did wood work was in High School.:lesson:
  2. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Hi - do you have direct links to the pics etc? You have to register on that forum to view the thread and I'm not sure too many people can be arsed (no offence)!
    Sounds good, anyway...
    MuFu.
  3. IPPacket
    IPPacket
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Looks quite nice.
    Might be worth putting up some specs in the DIY section.
    Do you have a frequency response curve for it?
  5. Sunday Ironfoot
    Sunday Ironfoot
    It's amazing how easy it is to build a subwoofer (with the exception of putting together the actual drive unit). Indeed a flat mate at university halls tried this with some success. Question though, how come subwoofers are generally quite expensive to buy? I would have thought that if anything cost good money to build, it would be the delicate tweeter unit.
  6. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Although it's easy to build a subwoofer, I'm sure it's pretty hard to build a *very good* subwoofer.
    MuFu.
  7. MikeK
    MikeK
    Why??? :confused:
  8. 64kym
    64kym
    Great looking Sub, what does it sound like ?? Are you useing it mostly for music or movies?
    Nothing more satisfying than a DIY jobby
    Stuart
  9. nathan_silly
    nathan_silly
    Have you braced the box? I think that's pretty important in a standard box cabinet.
  10. IPPacket
    IPPacket
    The sound quality is very good. It sounds and performs as well as a unit that cost at least double its price. I went and tested a few to compare how well it goes.
    I use it 70% Music (breakbeat, Drum n Bass) and 30% Movies. Sound quality is important to me as the boominess of bass wears off over time and quality is what you are after.
    nathan_silly - I did not brace the box as I used 18mm MDF..the cabinet dimensions(outside) are 500 high x 350 deep x 400 wide so the panels are not large enough to flex to any degree. Plus it is only a 150 WRMS amp so it wont be pumping *that* hard.
    I have posted up a few graphs.
    http://home.graffiti.net/ippacket/splcurve.jpg
    http://home.graffiti.net/ippacket/gaincurve.jpg
  11. IPPacket
    IPPacket
  12. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
  13. DaveP
    DaveP
    I see you have it near the tele, did you magnetically shield it? If so, how?
    DaveP
  14. IPPacket
    IPPacket
    No it is not magnetically sheilded as it may appear. I found out the effects of magnets on TV's pretty quick let me tell you. :eek:
    It is positioned just outside of the range that effects the telly. Amazing really the amount of clearance you need.
