Home Automation where to start?
Antexter
So basically I'm a huge fan of automating the home, currently though funds are limited.
What I'm hoping to get is ideally a system I can customise easily, maybe even go to the extent of making a web interface for controlling lights etc as I am a web developer.
Now from what I have seen x10 seems a good place to start but am I able to make a web interface easily?
If so is their a alternative?
If not where do i start with x10 what should i buy what would you class as essential, personally I'm lost in what i should get 1st.
Thanks.
chrisatapple
Hi Antexter
I'm a little new to Home Automation too. There is a fair amount of stuff available. I'm not too sure about connection via PC/MAC etc. However, I know that CH Byrons Home Easy range can be controlled via SMS messages. They can be used to control lighting, heating, cooling etc.
Hope this helps.
Chris
eyepete
Automated Home - Home is probably a very good starting point from a novice pov. Their forums are full of helpful people who can advise on the most cost effective way to get started - as well as give you the low down on what's hot and what's not.
Pete
mikeinmk
Hi Antexter
Hope this helps.
Chris
I purchased some home easy kit and have had no end of problems. I had 2 PIR's that do not detect movement. I had several of the remote control sockets (the one you plug into the wall socket) and they appear to have a life of their own as I used to come home and kit connected to the plugs would be powered on.
I found that when you paired the device with the remote that other remotes that had not been paired could also control the socket. I live in a apartment, I think some neighbors had also purchased some home easy kit and we were controlling eachothers stuff.
I recommended home easy to a friend before my problems started and borrowed their remote. I confirmed I could randomly power on my non paired kit.
Happy I did not buy the remote contolled door lock! :eek:
Mike
whzan
Hi Antexter!
Check out www.whzan.com it is a new home automation service over the internet and is currently free! There are easy to follow 'getting started' videos, and a shop to help you find the kit you need for your requirments.
