Home automation devices that works with RF 433Mhz
Discussion in 'Smart Home, Climate Control & Security Forum' started by Jaeke101, Sep 10, 2018.
  1. Jaeke101
    Jaeke101
    Aug 27, 2018
    2
    4
    Doha, Qatar
    Hi everyone,
    I have SAVVY Smart Home System installed in my home from ABOUT
    The system operates through RF 433Mhz, I have lighting control, Curtain control, Temperature and etc.
    Controller Spec: SAVVY CONTROLLER
    Input Voltage: 5V/1A
    Network Standard: Wi-Fi/ Ethernet Cable
    Wi-Fi Standard: IEEE 802.11 b/n/g
    Wi-Fi Frequency: 2.4 GHz
    Wi-Fi Power: 0dBm (Maximum)
    Supporting Devices: SAVVY Security Accessories (Door Sensor,
    Motion Sensor, Smoke Sensor) 315MHz wireless siren (1 537/2262 coding)
    Supporting RC Type: RF (315/433<Hz ASK), IR (26K-64K Carrier wave)
    Radio Frequency: 433MHz GFSK
    Antenna Type: Built-in Support IR
    Code Library Air-conditioner, TV, SIB
    Extension Function: SAVVY smart home and security devices, SAVVY
    supported manufacturer devices, third-party IR/RF control devices
    Working Temperature: 0-40◦C
    Now, i'm looking for a water leak sensor that i can add to the system.
    I'd love to hear your suggestions to where i can get a water leak sensor and other home automation devices that works with RF 433Mhz that i can try. any ideas?
