Hollywood + Successor Details
Discussion in 'Desktop & Laptop Computers Forum' started by Pygmy Hippo, Feb 7, 2002.
  1. Pygmy Hippo
    Pygmy Hippo
    Don't know if anyone is interested in this but sigma designs have just announced they are producing a new card in March called the X-Card ($99) and that it will have component and scart output and best of all will support divx.
    There's a press release at
    http://www.sigmadesigns.com/news/press_releases/020205a.htm
    I think it may be time for me to start saving the pennies again!
    Pygmy Hippo
  2. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +8
    I wanna see if the region changing can be done as easily on this as with the old one and the likes of Dvd Genie first. Even if the quality is great I still want unlimited manual region changes to be possible at least.
    If I can't do region changes it's useless. The price sounds good though especially if it comes with remote.
    Also I hope they somehow get around the old problem where you had to have a monitor plugged in to get to your desktop etc.
  3. mjn
    mjn
    May 24, 2001
    22,415
    Herts, England
    +10,422
    Then it would be a VGA card aswell!!
    But this card looks good, might have to replace my Dxr2 card finally!!
  4. Pygmy Hippo
    Pygmy Hippo
    On the newsgroups the bloke that works for sigma, Nagui, says that "It uses a new
    pass-thru cable that has virtually no degradation even at the highest
    resolutions/refresh rates offered by today's monitors/graphic cards"
    Whether it does or not is another matter - but there have been tons of complaints about the pass-thru cable in the past so maybe they have sorted it.
    Does anyone else believe in the conspiracy theory that DivX+ (the prog that lets u use divx on H+) was written by Sigma to test the waters for a proper card, bearing in mind that it would only work some of the time on a very strict configuration?
    Doesn't seem to be much about Region Selection on the ng's or anything i've seen yet - but lets face it someone is going to write a prog to get round it, they always do! (just watch then don't do it now just to spite me!!)
    Pygmy Hippo
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    never heard of divx+. where can i get it . i would love to be able to play divx stuff on my h+ :D
  6. mjn
    mjn
    May 24, 2001
    22,415
    Herts, England
    +10,422
    the pass thru-cable is only used to pass the VGA information, and if you plan to "overlay" the picture.
    If you use the deadicated outputs, the signal does not touch the pass thru cable.
  7. Pygmy Hippo
    Pygmy Hippo
    If you nip along to
    http://dvd.box.sk/
    then there is a download link to a prog called HHPlus 1.0.1.5 which does the DivX thing - it should work on 9x/2k but unfortunately not XP.
    The homepage for the prog has disappeared, or is down for the mo - so it may be best to get it whilst you can.
    Cheerio
    Pygmy Hippo
  8. Pygmy Hippo
    Pygmy Hippo
    If you nip along to
    http://dvd.box.sk/
    Cheerio
    Pygmy Hippo
  9. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    ok i downloaded it . it says in the readme file that you need divx+ installed for iot to work :( . i installed it anyway but it did'nt do anything at all
  10. Pygmy Hippo
    Pygmy Hippo
    Just in case anyone still hasn't found a copy of DivX+ it can be found at
    http://www.vcdhelp.com/vcdtools.htm
    its about halfway down the page and is only a small download, around 300k.
    Remember though that this is a very shaky piece of software, when it works its amazing, its just a shame that 99% of the time it just crashes.
    Good luck to anyone brave enough to try tho
    Pygmy Hippo
  11. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    thanks
    saddly it dos'nt seem to want to work for me at all . i just get an error message :(
    never mind
  12. Pygmy Hippo
    Pygmy Hippo
    Sounds about right - my experience of divx is that i managed to watch one film (Exit Wounds) and then when i tried to load in the next film it just didn't want to know. Nothing had changed - it was exactly the same configuration and it wouldn't even load Exit Wounds again.
    Wish i'd watched a better film now!! :)
    Still it was worth a try and there is always that X-Card to spend more bloody money on!
    Pygmy Hippo
  13. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +8
    I see the point, but frankly all those R1 discs i have will be pretty useless (ok, exaggerating a bit here as I do have my standalone player and pc). Progressive scan won't mean much either when I can't play these.
