Hmmmm! Sammy LE32R41BD or Sony KLV-S32A10
P
prycop
Sammy LE32R41BD or Sony KLV-S32A10?
Found a source for the Sony (£970) only £130 dearer than the cheapest Sammy (£840)
Which would you go for - what are the pro's and cons?
Surely a newer Sony TV is 'better'??
S
Shin Gouki
If you can afford the extra cash then you would be stupid to go for anything other than the Sony "S" . It uses the latest Sony/Samsung panel which has a response time of 8ms compared to 12ms for the Samsung LE32R41BD.
There is nobody on this forum who would choose the Sammy over the Sony "S" if they had the money to purchase the "S".
The fact that the Sony "S" uses the new 8ms Sony/Samsung panels is all you need to know. :thumbsup:
P
prycop
Glad to see the debate growing - comments appear to be 50/50.
I'm going down the track that latest screens must be better train of thought....
vallii
Sammy get my vote, say no more.
AcademicBarzo
Yes, there is! Me and I did. Saw the Sony in John Lewis, and saw no reason, given that this model does not have WEGA engine, for purchasing over the Samsung. It cost more, certainly, but the image seemed much the same, imho. In fact, if anything, a little worse. And, yes, I did have a play around with the settings. Made my decision that a Samsung was the panel for me - it cost £859.99 delivered, which was a major bonus, but not the reason for buying the panel. I had budgeted up to £1,500.
vallii
Faster 'Response Time' does not mean it's better, a 14ms Panny did very well (beat) against the 8ms Sony, check the latest mag out today.
chriszzzzzz
Sorry to rain on your parade but 8ms is the response time on the Sammy. Also the pic quality is superior to the Sony.
I think you will find many people on this forum who would choose the Sammy over the Sony. Sony is not the byeword for quality or top range it once was...
Random Hajile
I had the samsung panel for a month and sent back after that time so I know how well the samsung works with SD and Hi def material over TV and games. And I demoed the S series sony and can honestly say you will notice the sonys faster response time straight away especially playing soul calibur 2 in 720p. Prime example on soul calibur is where you first start the stage and the camera pans fast around the arena and characters and on the sony there`s no blurring what so ever where on the samsung panel there is slight blurring. Plus the sony panel seems alot brighter and slightly better contrast aswell. Don`t get me wrong the samsung is a great screen but anyone thinking It`s the same panel or as good as the sony haven`t clearly demoed the sony properly. Overall If you have the extra cash go for the sony as you are paying for a better panel and not just the name.
Random Hajile
Contrast Is 800:1 I think same as the samsung, It`s hard to describe but the overall image didn`t look as dull as the samsung when It came to displaying darker areas on screen. And As I said in a previous thread, with progressive sources you really need to ram the brightness up on the samsung to around +75 where on the sony being on 50 was perfect. Plus I found the sony image overall slightly sharper when It came to games (probably down to the faster response time)
richard plumb
to be fair, I think the differences are pretty small between them, and not easily quantifiable.
Therefore the best advice is that
a) both sets are very good
b) you need to see them both with your own eyes to decide.
You might notice if there is a difference in response times and prefer the Sony. Or you might like the 'look' of the Samsung - how an LCD presents its pictures to you.
S
Shin Gouki
ThePimpmaster said:
Sory to say it, by the Samsungs are 8ms as well. The Sony and Samsung havethe same panel.
No they are'nt they are 12ms. The only sets to use the new 8ms panels are the Sony "S", "V" and "W" series.
S
Shin Gouki
I think if you set them both up perfectly you would of gone for the Sony. Why anyone woudl go for a set with a 12ms response time over one with 8ms is beyond me. I would of taken the new 8ms panel right away.
You say you fiddled about with the settings but you didnt have the time to set them up perfectly and test everything.
Hey if i offered to buy someone one of these sets, and they choose the Sammy, i woud still buy them the Sony, and they woudl thank me for it later. ;)
Makes no sense to go for an older inferior panel, and further, more detailed testing would of showed that.
S
Shin Gouki
I don't trust magazines. What version of the Sony did they put it up against anyway?
S
Shin Gouki
:nono:
No, the resposne time for the sammy is 12ms and it does not use the same panel as the Sony BRAVIA series.
Many people have the Sammy over the Sony because the Sammy was released earlier and is now cheper than the Sony.
It's got nothing to do with the Sammy being better because it's not.
G
Gizmoboy
Shin Gouki,
With all due respect - you are wrong. I have seen the label on the physical LCD with 8ms written on it. I have seen the specs on the Samsung website. I have just returned from Dubai (and have seen the same sticker/specs stating 8ms). Perhaps you would like to check your information again?
Regards,
Gizmo
Random Hajile
I`d say after having the samsung It`s no way 8ms. After Demoing the Sony, I can believe that`s 8ms but I`d say the 12ms whats been quoted pretty much everywhere for the samsung Is more near the mark.
Are you sure you aren`t confusing it with the Samsung LE26M51B Milano Gizmo which is samsungs more expensive panel which has a 8ms response time?
S
Shin Gouki
It seems that there is a lot of confusion with these sets. The UK website does'nt give any info at all on response times. The american website says 12 ms and according to an email someone recieved the sets are 12 ms.
Is it possibe that they have upgradd the panles? because the whole point of people buying the new Sony Bravia sets is that they use the new 8ms Sony/Samsung panel, and no other sets used this panel yet.
Maybe they have started putting this panel in the Sammy? or maybe they just have an 8ms panel but it is'nt the new panel thats in the Sony BRAVIA series? :confused:
S
Shin Gouki
He must be talking about another set.
The main reason peope wanted the Sony BRAVIA series is becaue they have the new 8ms panel which no other sets were supposed to have.
G
Gizmoboy
Shin Gouki said:
Everywhere i look it says that the LE32R41B has got a 12ms panel.
Hi Shin Gouki,
Have a look at this link. I guess someone will just have to call Samsung directly!
http://www.samsung.com/fr/products/tv/lcdtv/lcd169/le32r41bxxec.asp
Again, I know the models as I wanted to buy this one and saw the updated m51 & 61 models as well. All had 8ms response times on them (sticker attached/specs attached). Maybe someone else could confirm!
Regards
Gizmo
S
Shin Gouki
Someone on the forum emailed Samsung about this and got a reply from a very helpful guy from Samsung. He said the LE32R41BD had a response time of 12ms and the only sets they sold that had a response time of 8ms are the M51 and M61 models. My guess is that they just stuck those stickers on all the sammy LCD's unless they have started to use an 8ms panel all of a sudden.
Here this is the email conversation they had-
"Dear ____
Thank you very much for your enquiry regarding Samsung LCDs.
The response time of these units is 12 ms.
Regarding the differences between these models it is purely design difference.
Both are HD Ready 32” LCDs with built in freeview digital tuners.
I hope this helps.
Rob Shaw
Product Manager CTV SEUK
Tel: 01932 455047"
______________________________________________________________
"Hi Rob
Thanks for getting back to me.
I was wondering, why do we have a lower response time in the UK product? On European sites for the same model it states 8ms: http://www.samsung.com/es/products/...=Specifications
Thanks for your time."
"Robs reply
Dear _____
I would suggest that some of the information on their websites may be incorrect.
From information we have been given the only current models we have with an 8ms response time are the M51 and M61 models.
I hope this clarifies
Rob Shaw"
