Hmmm...maybe a hopeless newbie question
Discussion in 'Blu-ray & DVD Players & Recorders' started by pisfin, Mar 1, 2005.
  1. pisfin
    pisfin
    Hi there,
    I hope that someone will answer a hopeless newbie question. I've just received a TV, that can manage prog. scan and I also have a Kiss DP-1500. If I want to use the prog. scan from the DVD, what connections can I use? Can I use the RGB scart from the DVD to the TV?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    The TV's manual should tell you the connection types that it can accept progressive on. Not sure about the DP-1500, I have a DP-450 and component is available on the SCART connector via component but you need a special cable to get at it. If you don't get any help here, KiSS players aren't too common, then you may get more help on KiSS' forum
  3. Astaroth
    Astaroth
    Jun 22, 2004
    3,708
    London
    +898
    You wont be able to use RGB scart, there are a couple of TVs that do component via scart but they are unusual and require different cabling.
    The majority require seperate component cables to link the DVD & TV but as KraGorn says it will depend on your equipment.
