Question Hmm...
Discussion in 'What Is The Best TV For You?' started by TheBBC, Jan 15, 2017.
  1. TheBBC
    TheBBC
    Jan 15, 2017
    2
    GB
    I need a TV with full HD and a 2 hdmi space any ideas
  2. Dodgexander
    Dodgexander
    May 29, 2007
    14,378
    +4,228
    Any TV will match your criteria.
  3. Nesty
    Nesty
    Aug 28, 2016
    59
    Ireland
    +11
    Surely the worst thread of 2017 contender?
  4. TheBBC
    TheBBC
    Jan 15, 2017
    2
    GB
    no it won't there are 3798 different tvs out there 309 of which have no port another 408 only have one
  5. Dodgexander
    Dodgexander
    May 29, 2007
    14,378
    +4,228
    I think any of the budget TVs from manufactures have at least 2 now. In have people complain when there's only 2. You need to give more detail about what you want from a TV. What will you use the TV for? How big do you want the TV to be? Do you need the TV to look good at a wide angle? How much can you spend? There are many questions and I'm sure if you had the most strenuous requirements you would find a TV that matches your needs.
