HL2 Stress test?
Discussion in 'PC Gaming & Rigs' started by BadAss, Nov 18, 2004.
  1. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    I'm running a P4 2.4 with Radeon 9700 and get 75fps. What are you guys getting?
  2. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    aka Billy Science - Suni ojna Tas
    +432
    <resolution><AA level><Ansio level><Relfection level><model detail><etc><etc><etc>
    ^ fill in the above - as they all make a hell of a difference
    with all on highest settings 1600x1200 I get around 75fps on an x800 (XT flashed ) A64 3500+
  3. AML
    AML
    Jul 22, 2004
    4,988
    Tokyo
    +229
    Agreed. Your Graphics card driver settings make a huge difference. The higher the settings, the poorer the performance, but the nicer the graphics.
    Resolution also counts.
    I got a P4 2.8, OC to 3.2ghz.
    2ghz RAM PC3200,
    BFG 6800GT OC (stock 370mhz) my OC: 400mhz, memory 110mhz.
    All driver settings full , all game settings full. resolution at 1280X1024.
    FPS= 60/65
  4. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    +432
    wack it on 1600x1200 -run the test and tell me what .... I reckon everyone should run it at top res ( so we can be incredibly nasty and laugh at the 2fps on some boxes ;) )
  5. Hawklord
    Hawklord
    Feb 15, 2003
    3,432
    Aldershot, Hampshire
    +260
    1600x1200 max everything with vsync off gives me 83 fps :D
    A64 3500+, 1024 mb xms3200 c2 pro, 6800GT @400/1100 using 67.02 beta drivers.
    Averaging about 70 fps in half life 2 though as there's obviously some slow down for AI and bigger environments. Looks absolutely fantastic :smashin:
  6. engaged
    engaged
    Jan 12, 2004
    179
    Edinburgh
    How do you show fps?
  7. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    You can run the Counter Strike stress test.
    Ive just changed all my settings.
    <resolution> 1600x1200
    <AA level> x6
    <Ansio level>Highest
    <Relfection level>Highest
    <model detail>Highest
    Get ready for it....................................................................9.09fps!
    The one thing I can't seem to change is the colour settings, 16bit to 32bit?
    So I changed it before I started CS.
    I dont think I'd ever play a game at a res of 1600 anyway, as everthing looks too small.
  8. Hawklord
    Hawklord
    Feb 15, 2003
    3,432
    +260
    In game you need to activate the console in the keyboard menu (under advanced). You get to the console by pressing the ` key (left of number one and above tab) and type cl_showfps 1 to get your fps:)
    Alternatively use the stress test on counter strike source to get an idea how well the game will run on various resolutions.
  9. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,620
    71
    Cambridge, UK
    +90
    Dell Dimension 8300, P4 3Ghz, 1Gb RAM, 120gb SATA disk GeForce ti4800
    I run the game @ these settings
    1280x1024 - its an LCD Flat Planel.
    Everything high, water=reflect all, sync=disable, Filter=trilinear, AA=none : stress test is 33.66FPS
    In game when I turn on Filter to say 4 or 8 x the game slows down but more noticable is the sound - very patchy ..
    Stress test with AF @ 8x - 23FPS
    I know I know I need a new GFX card to really do it justice :)
    Nige
