Hk25
Discussion in 'Blu-ray & DVD Players & Recorders' started by gastrobol, Jul 31, 2003.
  1. gastrobol
    gastrobol
    Jul 31, 2003
    13
    Are there any HK25 owners who can advise me please?
    I bought this DVDplayer as the review in what HIFI reported it could out put PAL progressive scan.
    BUT the user manual says it only outputs NTSC prog scan!!
    I belive that there is an upgrade file that can be put on CD to activate multiregion AND PAL prog scan.
    BUT it appears the upgrade files are the same as the firmware up grade files on the HK website
    The HK web site details that all models with WA0001-12582 and above have the latest firmware so dont need the upgrade!
    Also some people who applied the upgrade seem to have terminally damaged the unit.
    QUESTIONS:
    1) does the HK25 output PAL prog scan if model is >12582?
    2) If not,do I run the upgrade software on the HK site?
    3) Has any one successfully used this upgrade to activate PAL
    prog scan?
