D
daveroyt
Lent to me to trial by Andrew at Sheffield Sevenoaks (thanks again mate!) I gather this HK-badged PC-programmed remote is a Harmony model under the skin. I needed something that would work all my kit (see AV room for pics) and have shortcuts for the various ways I use it.
Basic setup sorted the simple bits VERY quickly, and although involves a fair bit of play for the non-standard settings (like having projector AND screen, DVD and HDD recorder as sources) have got it pretty spouse-friendly.
£200; worth a look if you're in the market...
