HK Suppliers ?
Discussion in 'AV Receivers & Amplifiers' started by scollops, Jan 16, 2004.
  1. scollops
    scollops
    Been to the local retailer to listen to HK 5550 setup against Denon3803 - got the urge to get the HK 5550 but having a mare trying to find suppliers - only found one cheapest at 749.
    Are there any other suppliers of HK - maybe do a package with speakers and cables etc. Get Infinity now instead of Kef after listening to them
    Anyone ??? Thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    scollops where did you demo? HK arent big on mail order and you will pay as much on net as in store. So do you like the Oreus HK combo better than the denon egg setup?
  3. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    Try Sevenoaks. I got my HK from their Leicester branch. I don't think there are great discounts to be had though.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Seven oaks is a franchise IIRC so vary's from store to store.
  5. scollops
    scollops
    Well must say I tried the Denon and Kef steup, my first choice. Sounded pretty good for cinema, but seemed better on the music side. Speakers sounded good although, something missing didnt have a punchyness to it - could of been the amp though.
    The HK seemed to be the reverse of the Denon - cinema was really good, speakers were just as good as before.
    Slapped on the Infinity's. Must say they were really good, easily handled the music, cinema - sounded brighter and sharper than the Kef. Then again I was told that Amp's and speakers normally have to be broken in for a good few days to get the benefits.
    As I was looking mainly for Cinema sounds rather than CD music, I favoured the HK and Infintiy Speakers (thanks Hornydragon) for the alternate choice of speakers.
    Just gotta dig deep and put my orders in.
    I would definately recommend getting a demo and listening to your proposed setup if you can - makes things alot easier (except paying that is).
    So not many HK suppliers then - hmm Infinity ???
    Thanks again everyone for the sound advice.
  6. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +63
    harman/kardon and infinity belong to the same group - Harman International (along with JBL, Lexicon and a few others). So, theoretically anyone distributing Infinity speakers, or JBL should be able to get a hold on h/k amps?
    Russell
  7. Jason Jackson
    Jason Jackson
  8. andyh41
    andyh41
    Dec 28, 2000
    249
    East Grinstead
    +3
    Just bought an HK 5550 for £699 from sevenoaks (Tunbridge Wells). I was expecting to pay the £850 as advertised, but at the till I was told it was now £699. :smashin:
    Apparently they are clearing stock for the new range - due in a month or two?
  9. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,288
    48
    London
    +27
    may I suggest that you look into the AVP 507.
    Similar spec I think can somebody confirm this....
    and you can get hold of one for £500 ish
  10. scollops
    scollops
    DOne some shopping round - Even called Tunbridge Wells, there £699 model is display models only. Anyways got a special new for £649 plus del HK 550 and £499 plus del Oreus Speaker package.
    Got the amp today - superb, speakers coming direct so early next week - no rush for me I just saved a few pounds.
