HK player help
Discussion in 'Blu-ray & DVD Players & Recorders' started by Synchronicity, Jan 9, 2004.
  1. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,815
    +214
    Had my new HK 2550 delivered today from Home Cinema Heaven,pretty quick I must say,only ordered it 2 days ago:smashin:
    I didnt have time to get stuck into the set up before I came to work but managed to get it all connected.When I tried playing a dvd everything was sort of pink:confused: I didnt want to start going into the menus and tweaking or Id have never made it to work:p
    Obviously Ill be getting stuck into the set up when I get home later but Im sitting here wondering if I have a dodgy player:( does anyone know any reasons for it to do this?(o and when I say pink,I mean everything is really PINK).
    I did try a cd,and the sound is EXCELLENT!My neighbours are really not going to like me very much at all:blush:
    JB
  2. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    sounds as though you need to change the video settings. If you have s-video sellected for example, but you have component connections made, everything is green until you select component video out. It may well be the same effect with different selections/connections.
    HTH
    Croc
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Happens on our demo DVD25 when player is in in wrong output for cables ie Component over S-video cable Assuming you are using Component PS set players menu and all should be fine!
  4. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,815
    +214
    Cheers lads,I thought(hoped) it would just be something like that :smashin:
    Cheers for reccomending it Horny,lol,its probably worth the £250 even if I only used it as a cd player:clap: excellent sound!
    Shows you how far things have progressed,my old Toshiba cost over 400 quid a few years ago and this player kicks its ass in every way:smashin:
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    SO have you sorted it then Jason?
    I am glad you like it it they turned out to be duff i could see you and Croc having a 'good ole fashion dragon slayin'!
    Its nice when people are happy!
  6. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,815
    +214
    Im still stuck in work so still havent had a chance to check the set up yet(I really do think thats all it is tho)but imo the sound was excellent and I would be happy with this just as a cd player,the fact that it plays films too is a bonus:rotfl:
  7. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,081
    41
    Tamworth, Staffs
    +21
    Remember you have a video bypass when in CD mode as well. V-OFF on your remote :smashin:
    Croc
  8. Synchronicity
    Synchronicity
    Mar 6, 2003
    2,815
    +214
    Had a little 5 minute tweak in the settings when I got in last night,and it was exactly what you said,set to s-video.
    All I can say is I was happy with my Z2 before,but now ITS PROPER BO I TELL THEE!:smashin:
    Cant really find a fault with it....errr,maybe it looks a bit cheap(looks exactly like my m8s 50 quid player:rolleyes: ).Thanks to you folks who reccomended it,:hiya:
    JB
    :smashin:
