HK DVD25 & progressive scan/aspect ratio problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by nobbydog, Dec 1, 2004.
  1. nobbydog
    nobbydog
    Jun 19, 2003
    262
    Comfy basket in the utility room
    :confused:
    I'll be as brief as I can. Just noticed that when I select progressive scan in the DVD25 set-up menu the screen aspect ratio seems to overstretch, ie. whether it is still in the set-up page or back to the dvd that is playing, the top and bottom of the picture is not visible. However, setting the output to interlaced the aspect ratio is fine. :confused:
    Any one either with the HK DVD25 or any other PS player noticed this, its definitely not right and means at present I can only watch dvd's in progressive scan mode if I put up with the image stretched top and bottom.
    Any help :lease:
