HK DVD25 Prog Scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by spanx, Oct 14, 2003.
  1. spanx
    spanx
    Hi guys,
    I purchased an HK DVD 25 yesterday to plug-in to my NEC HT1000, so get the benefits of progressive scan. Now I understand that the DVD25 only supports prog scan for NTSC disks, but are there any hacks/tricks to get it to play PAL disks in prog scan too?
    Many thanks,
    Steve
  2. Crocodile JD
    Crocodile JD
    Dec 11, 2002
    1,090
    41
    Tamworth, Staffs
    +21
    HK DVD 25 definately does Pal PS as well. Earlier machines required a hack which with a quick search on this forum would be easily found, but I thought later machines were pre modified to give Pal PS out of box?
    Croc
  3. JonathanKnight
    JonathanKnight
    Jan 7, 2003
    74
    West Yorkshire, England
    I got mine at the end of August and it was PAL PS out of the box. I couldn't tell you if that was done by the manufacturer or the dealer though. I think it was the dealer that did it before they shipped it to me.
