hk dvd25 hack trouble
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by stevetiler, Jul 2, 2004.
  1. stevetiler
    stevetiler
    Sep 13, 2003
    139
    Essex
    Could somebody please help me change a hk25 to multiregion?I've downloaded the patch and followed the instructions as they appear at apache.com,but when i place the cd rom in the dvd tray thats when I get confused!What EXACTLY do I do after the disc is in the tray,the screen goes pink and there are various things on the screen that I dont understand!I'm afraid I need an idiot proof guide to the installation please,many thanks -Steve
  2. stevetiler
    stevetiler
    Sep 13, 2003
    139
    Essex
    anybody,please!
  3. stevetiler
    stevetiler
    Sep 13, 2003
    139
    Essex
    Anyone out there?
  4. technovorgin
    technovorgin
    Jun 16, 2004
    233
    Leeds/Wakefield border
    To Create The Patch CD
    Click on the 'dvd25_upgrade' icon above to download the ZIP file.
    Unzip the file, creating two .bin files: 'hkdvd25.bin' and 'dvd25_2.bin'.
    Using 1 x copy speed, burn the files on a CD-ROM in a folder called hk_dvd25.
    To Run The Patch CD
    Connect DVD via Composite connection to a video monitor (TV, Plasma, Projector etc.)
    Empty DVD tray
    Switch DVD to STANDBY
    Point remote handset at DVD and press the 'CLEAR' button, after 5-7 sec. the DVD will switch to 'ON'
    Place upgrade CD-ROM in tray and close tray
    Follow instruction on screen
    When upgrade process is complete the DVD will switch itself to 'STANDBY'
    Open tray and remove CD-ROM disc
    The upgrade is complete
    hope this helps
    bought mine ready done but my mate followed the above and his worked fine :)
  5. stevetiler
    stevetiler
    Sep 13, 2003
    139
    Essex
    Thanks for the reply,the trouble I have with this method is the "follow the onscreen instructions" step,all I get is "mp3 player" and a couple of other words that I dont seem to be able to do much with!Do you think the disc is faulty.I followed the instructions to the letter!
    Steve
