HK DPR 2005 lip-sync problem and multi-zone problem.
Discussion in 'AV Receivers & Amplifiers' started by eporopat, Dec 23, 2004.
  1. eporopat
    eporopat
    Is anybody else experiencing lip-sync'ing problems with their DPR 2005?
    I'm waiting to hear back from HR technical support over the matter. It seesm to be ok from my DVD player using the optical cable. The problem is running it over Foxtel Digital Sat. receiver using the spdif connector.
    Also I'm having issues getting the multi-zone IR working from another room. Sometimes the remote control works and others it doesn't. also waiting to hear from HK.
    Eddy
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Welcome to the forums :thumbsup:
    This can a common problem when viewing sat/terrestrial broadcasts. Doesn't the DPR 2005 have some kind of lip-sync delay? I think it does, you can use this to delay the sounds from your speakers so they align with your monitor. There should be something about it in your manual.
