HK AVR 630 and system audio 1730
Discussion in 'AV Receivers & Amplifiers' started by matty100, Dec 5, 2004.
  1. matty100
    matty100
    Hi All
    does anybody have HK 630 and sytem audio 1730 tower speakers?
    will towers be a big improvment over my Jamo statalite speakers?
    will the HK have a problem to drvie 4 ohm speakers?
    thanks
    Matty
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,447
    United Kingdom
    +1,827
    The HK won't have a problem driving 4 Ohm rated speakers as it has a very good power supply. Can't comment on the speakers you mention as I've never heard them.
  3. chrisp1
    chrisp1
    I own the HK AVR 630 and it drives my mission floorstanders with ease - although they're 6ohm, rather than 4. In particular dialogue is very clear and punchy sounding via my KEF 100c, which is also 6ohm.
    If you're worried by the 75 watt power rating, don't be. There's 75 watts and 75 watts, if you know what I mean. My old Yamaha was rated at about the same output (70 wpc), but the HK blows it away.
