HK 25 hack
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jazz Monkey Jr, Jul 16, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Can anyone tell me the hack for multi-region on the HK25, I found one on here that I tried but it doesn't seem to work?
    Has anyone got it to work?
    Also any tips for getting the most out of this DVD player - I am using it through component to my PV500 plasma, letting the plasma do the progressive.
    Mal
  2. Prayer
    Prayer
    May 12, 2005
    10
    Tallinn
    http://www.internetteam.de/zaphod/download/firmware/Harman_Kardon/DVD-25/
    Is this the one you tried?
    It says in the instructions that you should burn the upgrade CD with 1x speed. This can be a problem with today's PC hardware - I can burn CD-R with minimum 4x and CD-RW minimum 8x speeds with my PC.
    I just flashed my DV-575A today - burned the CD with 4x speed, "Disc-at-once" method and finalized the CD.
