Hive in two Separate Properties ?
Discussion in 'Domestic White Goods Forum' started by robinhood1701, Nov 8, 2018.
  1. robinhood1701
    robinhood1701
    Apr 8, 2006
    598
    Sherwood Forest, UK
    +15
    can you install hive systems in two seperate properties to control the heating systems in each from the same app with one master log in ?
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,077
    +6,958
    According to the hive website:
    ''Yes, but you will need to have separate Hive products and log-in details for each property.''
  3. robinhood1701
    robinhood1701
    Apr 8, 2006
    598
    Sherwood Forest, UK
    +15
    Ok, but do you have to log out of one to log in the other, or can you access both after setting both up on the app ?
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,077
    +6,958
    You would have to log out then log in.
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,077
    +6,958
    Someone on the Hive website has suggested a workaround:
    ''Workaround (at least on Android) is to use App Cloner available from the App Store. This can make you a second HIve App which works completely separately from the original, you even get to choose a name so can call it name of second home, or Hive 2 etc. Each can run concurrently on your device and they stay logged in - so you still need two logins but saves having to logout and login on the original hive app.''
  6. robinhood1701
    robinhood1701
    Apr 8, 2006
    598
    Sherwood Forest, UK
    +15
    Thanks Gav, that’s a b****r, but what i expected, and i have a iPhone, i May look elsewhere, but it’s something that hive could be improved by.
