Hitatchi 42PD5200 and analogue tv
Discussion in 'Plasma TVs Forum' started by aylmera, Jul 28, 2004.
  1. aylmera
    aylmera
    Hello
    This might sound a stupid question, but i was just enquiring as to whether the Hitatchi 42PD5200 allows you to view analogue television, as i have been told that it is strictly a digital tv. Is this correct?, or have i been given incorrect information.
    Thanks for your time
  2. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    this screen has an analogue tuner built in
  3. aylmera
    aylmera
    Thank-you for your reply. (it seems this is the only place you can actually receive correct advice regarding plasma)
  4. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    Has an analogue tuner on the 5200 model, but all reviews have found the picture using that source is not too good. Have a look at one set up in Currys, Comet etc for the proof. They nearly always have every set in the place running off a generally moderate quality distributed analogue signal. It then of course makes all the bigger screens look cr*p.
    Try and find somewhere that at least has a 5200 hooked up to a decent DVD player for an idea of the picture quality. Oh, and check which connection method has been used. I recently saw a 5200 hooked to a DVD player, with the player set to output in COMPOSITE mode. :rolleyes:
