Hitachi WF C36810N Engineers menu??
Discussion in 'General TV Discussions Forum' started by basharat, Jan 22, 2002.
  1. basharat
    basharat
    Any info on the engineers menu on this tv??
  2. sbrads2424
    sbrads2424
    I don't know this model, but Hitachi service menus are often accessed by holding both the TV's volume buttons down for 5 seconds and then pressing the handset Menu button for 5 seconds until a second menu appears. Be careful to note settings for each picture size/ratio before adjusting. You may have to exit in a particular way to actually save any alterations made, on my C28WF535N you have to OK on the EXS menu option and then go to Standby. You get a load of HEX numbers on-screen if you exit wrong!
  3. basharat
    basharat
    Thanks for that, I will have a go at it to see if I can solve this.
  4. RobCr
    RobCr
    Oct 27, 2008
    4
    I have the C28WF535N
    I need the Service Menu codes for Horizontal Left Right and Width.
    (Wouldn't mind the height as well).
    Could you post those, or point me to the Data Sheet ?
    Thanks,
    Rob (Australia)
    PS my profile allows direct email, if this forum does not allow attachments.
