Hitachi Wall Mounting Bracket - Good Question
Discussion in 'Home Cinema Buying & Building' started by AKM, Nov 1, 2004.
  1. AKM
    AKM
    Nov 1, 2004
    149
    Gerrards Cross
    +42
    Hi All,
    This is my first post even though I been using your helpful advice for ages! The time has come to buy a plasma. I have decided to go for the Hitachi 42PD5300 so that i can easily mount this on the wall without having to worry about wires (coz of the AV box!).
    I am moving into a new house and the guy i'm buying from has a wall mounted Hitachi 32 inch installed already. he has agreed to sell me the wall bracket and the 10m wire (which he says are worth more than £500 combined) for £250.
    Is the bracket the same for all Hitachi's i.e. 32/37 and 42 inch?
    If this is the case I can just hang my Plasma and go?
    Will the 42" hang higher from the floor than the 32"?
    Your advice would be apreciated
