We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Hitachi TX100 Problems
Discussion in 'Projectors, Screens & Video Processors' started by peve3, Nov 6, 2005.
  1. peve3
    peve3
    Aug 14, 2002
    438
    My TX100 seems to of developed a problem where the left part of the image is super sharp, but the right side is really blury. Meaning viewing is starting to become painfull on the eye.
    Is there any way i can remedy this fault ?
    It could be the lens on the front, but i bought a can of air to blow any dust of but it did not make much diffrence, im tempted to rub a cloth over the lense but feel it could make it worse.
    Any ideas ?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    You can clean the outer lens with a lens cloth no probs. Are you using lots of optical lens shift - this can cause uneven focus. However I don't think it would cause the image to be "really blurry"...PJ
