hitachi tx100 gone black&white
Discussion in 'Projectors, Screens & Video Processors' started by reeceglen, Jun 10, 2005.
  1. reeceglen
    reeceglen
    Feb 9, 2004
    yorkshire
    Has anybody got any idea why my projector as suddenly gone black&white.I'm using component cables when it first started i tried just the video cable colour is on with that input,so then i tried direct input with xbox component cable still b&w.I've not changed any settings or anything looked through manual but no joy.So i'm at abit of a loss to what is wrong :confused: any help would be welcome.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I don't understand :confused:
    The colour information in component is carried by all 3 cables ? If you just plug the green cable in, you should see a green picture.
  3. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    does it do this on all inputs ? what else have you tried connecting bar xbox ?
  4. reeceglen
    reeceglen
    Feb 9, 2004
    yorkshire
    i've connected all 3 component connectors to dvd player all working fine just done 116 hrs turned projector on today it come on in b&w.so just to make sure the cable was not at fault tried my xbox component cable that was b&w then i've got a seperate cable spare which i then tried in the video input picture colour on and yes i did take the 3 component connectors out. LIke i said before i've not changed any settings so cannot understand why it has done this. cheers for your help
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Is it the particular disc. NTSC etc?
    ...PJ :)
  6. reeceglen
    reeceglen
    Feb 9, 2004
    yorkshire
    sorry pj i'm a bit thick so i dont know so if you could explain a bit more that would be great.
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Is it now b&w on all DVDs you try ie ones that were in colour before?
    ...PJ :)
  8. reeceglen
    reeceglen
    Feb 9, 2004
    yorkshire
    yes all i get is b&w weird or what.I think pj must be faulty.
  9. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    seems that way. good news is the hitachi customer support imo i found is excellent and very fast. called them before 10 or 12 on a weekday and they have some one to pick up the machine that same day with a 5day turn around :thumbsup:
  10. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    ...Not true, with component video also referred to as a YPbPr or YCbCr signal, The Y component (the green socket) of this signal is the black and white information contained within the signal. The Pb and Pr signals are colour difference signals. The Y signal contains full bandwidth black and white picture information, and the colour difference signals contain bandwidth reduced colour information.
    Reeceglen,
    I'm afraid that I find it difficult to understand your post......... other then that you've got a black and white picture.
    It's possible that the input of the projector is set to composite video. When you'd connect composite video you'd get a colour image, when you'd connect component video, you'd get a black and white image. Try checking what the input of the projector (you should find it in a menu) is set to.
    S.
  11. reeceglen
    reeceglen
    Feb 9, 2004
    yorkshire
    theritz i have looked at inputs this is on auto,any way got a plane to catch so thanks for everbodys input and i will sort this out after my holiday.
  12. andyfel
    andyfel
    Hello mate, I have the same problem with my Sharp PJ. Its ok with SVGA/D Sub, but erratically it goes B&W with composite or SVHS!!
    Have you sorted your problem out!
  13. reeceglen
    reeceglen
    Feb 9, 2004
    yorkshire
    sorry for late reply but computer playing up now,anyway took projector back to shop and they just exchanged it :thumbsup: so no wiser to the problem. :confused: Thanks for all help given.
