rapid said:Does that just bolt into a ceiling joist or do you get bolts that fold out so it can be mounted anywhere on the ceiling?
Thanks,
R
jamieuk23 said:sorry to confuse you but have you not heard about HD72 DLP PJ which is released soon
http://www.discounttv.co.uk/product/Themescene_HD72_Projector_Hot_Deal.html
Just that you get a free screen + mount with it and it will be better overall Quality than the TX200
nickp8 said:Hmm where all the tx-200 owners hiding?![]()
nickp8 said:Thanks for the link fallwood but there is no way I would trust a £8 mount to hold a £1.3k projector!
jamieuk23 I am after a LCD not DLP.
jamieuk23 said:and it will be better overall Quality than the TX200
Dav0 said:I looked around and like you, didn't fancy mounting mine on a bracket that looked like my son had made at school...
